Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Drivetrain
Differential
Axle
Seal
Replace/Remove
The differential axle seal leaks ?
2004 FORD RANGER
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
HJBFREEMAN
MEMBER
1 POST
the differential axle seal leaks where. what is the procedure to replace this seal?
Feb 3, 2008 at 2:15 AM
Experienced Mechanic
Here are a number of guides that help with this by giving good detail on how to replace the axle seal and bearings if that is needed as well:
https://www.2carpros.com/articles/rear-axle-seal-replacement
Also, below is the process from the manual that will help replace the axle.
Please let us know if you have other questions. Thanks
Images (Click to enlarge)
Jun 2, 2021 at 12:53 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
