2004 Ford Ranger o/d light
41,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTJEN23
I bought my truck with 10,000 miles on it and at about 15000 the over drive off light started coming on then going off and the transmission was sticking between gears. i took it to the dealers and they said that they had fixed the problem and now its doing the same thing. its sluggish, and the transmission is sticking and not shifting up.
Feb 27, 2008 at 9:37 PM
MERLIN2021
  • 17,250 POSTS
TSB#:05-15-3 Issued on:08/02/2005
If MIL is on and code P0733 comes up, and there may be other codes too, you might have a defective pressure control solinoid, Go to Ford and refer to this TSB, you may get it for free if you tell them it should have been done when you had a warranty!
Feb 27, 2008 at 10:10 PM
