2004 Ford Ranger front pulleys
2004 FORD RANGER
MATTHEW.MARVIN
Noises problem
2004 Ford Ranger 6 cyl Two Wheel Drive Automatic
got a pulley squeaking do i replace it and how do i know which one it is for sure is there away to stop the squeaking without replacing it
Dec 8, 2009 at 11:16 AM
  • 31,937 POSTS
Hi there, i feel that this may be a belt issue, first check belt tensions and belt condition, check this first, if belts are ok, remove and feel for any tight spots or listen for any noise when you spin them often you will pick up a problem this way.
mark (mhpautos)
Dec 8, 2009 at 11:27 AM
