Engine misfire?
54,000 MILES • 6 CYL • 4WD • AUTOMATIC
KIKAMA
engine light blink put scan code is304 misfire cylinder 4 remplace spark,wires,coil pack,inj same problem
Mar 30, 2008 at 9:23 AM
KIKAMA
[quote:82d47749d0="kikama"]Engine Mechanical problem
2004 Ford Ranger 6 cyl Four Wheel Drive Automatic 54000 miles
engine light blink put scan code is304 misfire cylinder 4 remplace spark,wires,coil pack,inj same problem[/quote:82d47749d0]
Mar 30, 2008 at 9:42 AM
FLEXY5
  • 512 POSTS
Check for an intake leak. Spray some carb cleaner around the intake and near the head. Listen for a change in the way the engine runs. Post back with what you find and we'll go from there.
Mar 30, 2008 at 11:47 AM
