2004 Ford Ranger Cigarette lighter and other charger source
90,660 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMHOLGUIN78
Both my cigarette lighter port and my 12 volt port are both powerless. I have tested them both with a light tester and the light did not go on. I replaced the fuse, and still no power. Is there anything else I can do or do I need to take it into the mechanic?
Aug 10, 2010 at 11:09 AM
LEGITIMATE007
  • 5,121 POSTS
do you have a remote starter?
Aug 15, 2010 at 3:26 AM
ADAMHOLGUIN78
No, I do not have a remote starter.
Aug 17, 2010 at 6:57 AM
LEGITIMATE007
  • 5,121 POSTS
ok, remember, you will not get power to those two items unless, the key is in the on position or the car is started. have you checked it that way?
Aug 17, 2010 at 8:03 AM
ADAMHOLGUIN78
yes i have tried the test with power on.
Aug 18, 2010 at 6:20 AM
LEGITIMATE007
  • 5,121 POSTS
I believe there is a relay switch that goes along with the regular fuse, if they are ok then look for the ground, for them, they are most likely both on the same ground which is why they both arent working at the same time. then I would consider, having the body control module inspected for a short
Aug 19, 2010 at 8:41 AM
