at work and brakes suddenly locked up
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
RODNEYG
I was pulling out of my parking lot at work and brakes suddenly locked up. It felt like they were dragging the 5 miles or so on the way home. When I got home they smelled hot. After they cooled, I checked the pads and rotors and they seem fine. Now it feels like I am "loosing pedal" and there are no leaks. Could this be a master Cylinder or ABS problem?
Dec 29, 2008 at 8:30 AM
RANGERDANGER17
  • 224 POSTS
This happens when the brake booster push rod is adjusted out too far which does no allow the brake master to return fully holding the brakes on . To confirm the issue loosen the brake master mounting bolts 3 turns to see if the car starts to roll again, if so remove the master and adjust the booster push rod inward. Also a brake flex hose can come apart internally causing a short of check valve in the system but this is usually isolated to one brake either front or rear.
Dec 2, 2017 at 6:50 AM
RODNEYG
Thank you it was the brake master that was bad, thanks for the guides they help me fin the problem.
