2003 Ford Ranger Starting issues
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRASSTEC
The truck has always cranked smoothly and quickly. Recently, it's cranking slower/harder and when doing so causes the door locks (automatic) to lock and unlock. Could this just be the battery or should I look deeper for more electrical problems?
Oct 17, 2008 at 2:13 AM
RENAUDTN
  • 636 POSTS
check voltage at the battery (should be 12.6V with car off)
Below 12.6V?: recharge battery/jump start and try to start the car. If car starts check voltage at the battery again; you should read between 13.9 and 15V; if not your charging system is not working right.
To make sure you battery is okay, you can also take it to a battery store/autopart store and have them hook it up to a tester. They'll be able to tell you right away if your battery is still good or need to be replaced.
If your battery tests okay, come back to me and we'll look at other possible problems.
Oct 17, 2008 at 5:57 AM
