2003 Ford Ranger No Power
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
WDMG14
Replaced coil, plugs ,fuel pump, converter, ........ checked compression. Engine idles well, but does not have any power while driving.
Jan 16, 2010 at 8:54 AM
  • 75,988 POSTS
Check and test the following below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Jan 16, 2010 at 2:01 PM
