2003 Ford Ranger need help diagnoseing problem.
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDREWPATTY
So i purchased this truck in December of 2009. It ran great at first, but as i was driving it home, i went up a steep grade and it began to shutter and really had to work up the hill, even when i shifted into second gear.
After i got it home everything was OK, until a couple weeks later, when i turned on my truck, put it in gear, and then didn't move anywhere. i just sat there. If i give it some gas it will begin to move. Sometimes i need to get the rpms to 2500+. Other times it starts moving at lower rpms. Sometimes it happens when my temperature gauge is in the middle, reading what i assume is "warm". This is an intermittent problem. Sometime i hop in and it turns on and drives great. their is also a random rattling every once in a while when accelerating. I'm not sure what/where it is.
A buddy of mine told me it was something wrong with my transmission, and possibly my torque converter. i have no idea and would like any help possible. thanks in advance.
I bought the vehicle at about 103000 miles, and since have replaced my tranny filter, gotten the fluid flushed, added lucas stop slip, and im not quite sure what else i can do to help besides a rebuild....
Apr 21, 2010 at 5:40 AM
  • 75,988 POSTS
Inspect and test the transmission range sensor if okay get the transmission pressure tested to identify internal problems-
Apr 21, 2010 at 8:42 AM
