2003 Ford Ranger jerking forward
2003 FORD RANGER
107,500 MILES • 6 CYL • 2WD • MANUAL
TYPEORANGE
When i drive my truck and i start to get up over 3500 rpm my truck will jerk pretty rough. It feels like when you pop the clutch and it jerks. Happens in 1st 2nd and 3rd mostly. Do you know what could be the issue? My truck does need a tuneup and i should be on that soon. I just had the clutch and slave cylinder replaced back in october. It started doing it maybe a month or 2 ago. Thanks - Randy
Mar 8, 2010 at 11:19 AM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 8, 2010 at 11:39 AM
