2003 Ford Ranger Idle squeak
2003 FORD RANGER
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
ECHOZULU
My truck has a squeak somewhere in the engine, or somewhere in the front of the vehicle, when it's idling.
When I push the gas it goes away. As soon as I get off of the gas pedal the squeak comes back.
I'm pretty sure that it's not the brake pads because the squeak remains even after the vehicle has stopped.
I had my timing belt changed a couple of months ago because it was squeaking, could it be the belt again?
Thanks for your help.
Tom
Dec 22, 2008 at 2:36 AM
RACEFAN966
  • 5,029 POSTS
Timing belt? I have yet to see a ford ranger with a timing belt unless it has 4 cylinder. DO you mean the serpentine belt? Anyway as for the engine noise I would check the idler and tensioner pulleys for the serpentine belt system first then check the altenator. If you don't have a long screw driver to use a stethescope then you can buy a stethescope at an auto parts store pretty cheaply.
Dec 22, 2008 at 3:55 AM
