2003 Ford Ranger fuel filter removal
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
GRIFTER1959
I tried using the removal tools to remove fuel filter but noticed I can only remove 2 lines and the 3rd line is to close to the filter housing to get the tool under it. Is there a special tool for that one line? any help would be appreciated since I have not changed this filter since I own this tru new.
Jun 12, 2009 at 3:13 PM
DONOVANCAM
Removing the fuel lines from the filter DOES require a special tool. I made the mistake of buying the universal AC/Fuel line tool - this will not fit the fuel filter. There is another tool - small plastic ring remover available in a couple of sizes. Find the right size for the fuel line connector and use this instead, it should fit over the stem between the connector and filter. The scissor-like aluminum universal tool does not fit.
If you accidentally break the connector, an aftermarket one can be found - but it will take A LOT of searching and will most likely have to be ordered.
Jun 13, 2009 at 2:04 AM
