Are the front Brake Rotors seperate from the hub assemblies and bearings, or do you have to change everything together??
May 19, 2008 at 7:14 AM
MERLIN2021
✓Experienced Mechanic
You remove the dust cap, then the cotter pin, then the axle nut, then pull the rotor!
May 19, 2008 at 7:37 AM
