my engine just started to squeak today. belts are fine. sounds like it is coming from the rear of the engine. ac is not on.
Jan 10, 2010 at 9:56 AM
✓Experienced Mechanic
THere really isn't anything in the engine that would squeak. Are you sure it isn't a belt? If you pour a small amount of water on the belt, does it go away or change? NOTE: If you do this, make sure to protect your eyes.
Jan 12, 2010 at 12:23 AM
JAMES DERICKS
MEMBER
1 POST
I have a 2003 Ford Ranger, the same problem is hapening to mine. A squeel is coming from the back of the engine. What was it with yours? Did you ever find out? my neighbor says it may be a lifter in the engine. Hope you found the problem, please let me know.
