2003 Ford Ranger Clutch Fluid Leak
97,000 MILES • 6 CYL • 2WD • MANUAL
JD329
  • 16 POSTS
My clutch hydraulic fluid reservoir has ran out of fluid twice now. The fluid is leaking out the bottom of the bell housing. I am pretty sure its the slave cylinder but just wanted one more opinion before I shell out the big buck$.
Dec 7, 2008 at 4:22 AM
DAVE H
  • 13,383 POSTS
it will be the slave cylinder ..
Slave Cylinder
Removal
Remove the transmission. For additional information, refer to TRANSMISSION .
NOTE:Inspect the clutch housing for traces of fluid. If brake fluid is visible, install a new clutch slave cylinder.
Remove the clutch slave cylinder.
Remove the bolts.
Fig. 17: Removing Clutch Slave Cylinder
Courtesy of FORD MOTOR CO.
Inspect the clutch slave cylinder for the following:
Worn or damaged boot.
Leaking fluid.
Worn or damaged bearing.
Inspect the clutch release bearing as follows:
Rotate the outer race while applying pressure. If the bearing rotation is rough, install a new clutch slave cylinder.
Inspect for wear or damage.
Installation
To install, reverse the removal procedure.
Position the clutch slave cylinder to the transmission and install the bolts.
Fig. 18: Installing Clutch Slave Cylinder
Install the transmission. For additional information, refer to TRANSMISSION .
Dec 9, 2008 at 2:50 PM
