2003 Ford Ranger Clutch
2003 FORD RANGER
87,000 MILES • 6 CYL • 2WD • MANUAL
MIKELKELLY
The clutch does not seem to want to engage. Not sure what or where to check for problem or adjustment.
Mar 14, 2010 at 4:25 PM
BLACKOP555
  • 10,386 POSTS
ok. clutch engaging as in moving the vehicle or when you push on the pedal its not disengaging. some people mix it up and we go the wrong way. so any info you can provide is greatly appreciated.
Mar 14, 2010 at 11:11 PM
MIKELKELLY
Truck lunges forward when started in gear and will not shift into gear when started in nutural.
Mar 15, 2010 at 8:57 AM
BLACKOP555
  • 10,386 POSTS
ok so the clutch is not disengaging. sounds like a linkage problem. do you have a hydraulic or mehcanical clutch first of all.
Mar 15, 2010 at 9:19 AM
MIKELKELLY
The clutch will not engage when truck is running and it lunges with the clutch in when started in Gear. Tryed to bleed the clutch but that did not work or we did some thing wrong. I open the zert had them pump the clutch peddel twice then tightened it up while the cluch was still in. It squerted out some fluid and air then just fluid when I tightend it up. Replaced the fluid used up in the master cyclinder and there was still no clutch.
Mar 15, 2010 at 8:58 PM
