2003 Ford Ranger clutch
80,600 MILES • 6 CYL • 4WD • MANUAL
K1853W
My 03 ranger was in need of a slave cylinder probably 2 yrs. ago so recently at 80500 i had a clutch kit installed. Now the cluth pedal seems much harder to push down and i don't seem to have the pedal height that i used to. Is this common? Should the pedal be harder to engage? I've bled the lines so i don't believe there is any air present, and the slave is what is refered to as self adjusting. My brother has a 93 ranger with the same difficulies. Any advice from anyone on this matter would be much appreiciated!
(gotta love that internal slave cylinder)
Feb 21, 2010 at 8:07 AM
  • 110,246 POSTS
Actually, what you described is common. If you used an aftermarket part, it will be different. As far as the internal slave, you mentioned the word "love." I have a different name for it but can't say it online.
If the clutch is working properly, you did a good job. It just has a different feel to it.
Mar 1, 2010 at 3:13 PM
