2003 Ford Ranger clunk when coasting in neutral
65,000 MILES • 6 CYL • 2WD • MANUAL
JAMES MAASS
When I coast and then brake with the clutch engaged or in neutral I hear a clunking noise within the trasmission. I can feel it thru the shifter. Sometimes this also happens when I accelerate normally from a stop.
Sep 12, 2009 at 11:38 AM
DONALDGOLDSR
  • 38 POSTS
[quote:e70a044728="james maass"]Transmission problem
2003 Ford Ranger 6 cyl Two Wheel Drive Manual 65000 miles
When I coast and then brake with the clutch engaged or in neutral I hear a clunking noise within the trasmission. I can feel it thru the shifter. Sometimes this also happens when I accelerate normally from a stop.[/quote:e70a044728]
Sounds like either the transmission mount broken, or possible the universal joint carrier bearing
Sep 14, 2009 at 1:40 PM
