no clutch at all and can't find a bleeder valve
55,000 MILES • 6 CYL • 4WD • MANUAL
HYPNOTIX_20
I have a 2003 Ford Ranger Xlt Fx4 and my clutch pedal was feeling a little weak so I checked the fluid. It was alittle low so I added some and now I have no clutch at all and can't find a bleeder valve on the line anywhere. Where would I locate it?
Nov 8, 2008 at 4:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It will be located near the bell housing where the slave cylinder is.
May 4, 2021 at 3:14 AM
HYPNOTIX_20
My slave cylinder is located inside my transmission case though. I finally located the bleeder valve and have used an entire bottle of fluid bleeding it and have a decent pedal but i still can't put the trunk into gear. Am I missing something?
