2003 Ford Ranger altenator
136,000 MILES • 4 CYL • 2WD • MANUAL
DARRRYL CORNS
How do you replace the altenator?
Mar 29, 2010 at 12:02 AM
TOOOMANYTOYS
  • 513 POSTS
REMOVAL
Disconnect the battery.
Remove the air cleaner outlet tube.
Remove the accessory drive belt.
Remove the bolts and position the generator aside.
Remove the generator.
Remove the nut and disconnect the electrical connectors.
INSTALLATION
To install, reverse the removal procedure.
Mar 29, 2010 at 12:12 AM
