2003 Ford Ranger AC problem no pressure through vents only
524SUPPORT
  • 2003 FORD RANGER
  • 4 CYL
  • 88,000 MILES
My ac was working fine then one day I only got air pushed from the vent through the windshield defroster vents. My friend saw a plug under the glove compartment and reconnected it and now I got air going through all the vents, but the problem has reappeared and I don't get air pressure through any of the vents except the defrost vents just below the windshield. What could it be. Thank you very much for your help I will do my best to give good points for good answer, and I will try anything you tell me. Have a great day. No make it a great day. Bless
Monday, July 5th, 2010 AT 10:25 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Vacuum supply fault without vacuum from engine system goes to default ie. blows only from defrost. Underhood near heater oses and A/C lines to evaporator find vacuum line see if connected and has va cuum supply. see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_505.jpg
Let me know
Thanks for donate
Monday, July 5th, 2010 AT 12:22 PM
