Replacing the brake shoes didn't cause the problem. Check to make sure they didn't damage or disconnect one of the sensors at the wheels. Also, most parts stores will scan the computer to determine why the light is on for free. Finally, to reset the light, you can try disconnecting the battery for about 10 minutes, but you will most likely need a scanner to reset it. Keep in mind, there is a reason it is on. That is why I recommend having it scanned. Also, if the light is on, the ABS will not work if you need it.
If you have other questions, let me know. Have a great new year and thanks for using 2carpros.com.
Apr 27, 2021 at 3:21 AM
