2003 Ford Ranger
91,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANDREWCOTTONE
I recently changed the transmission fluid and filter. After draining the fluid and removing the pan, there were three small pieces of metal (stainless steel ?) approximately 1/32" in diameter and shaped like a cylinder. They are approximately 1/32" in height. There was also a brass or copper washer (cresent shaped). It appeared to have broken loose from the other half. Before the service, I had no problem with the transmission shifting as well as afterwards. Everything appears normal. Are those pieces that were in the bottom of the pan anything to be concerned about?
Mar 4, 2010 at 5:24 AM
2CARPRO JACK
  • 11,533 POSTS
Anytime you find "hard" metal in the pan you should be concerned.It may be a roller bearing that is falling apart.This could turn into something expensive.I would have a trans shop look at the pieces you found and go from there.
Mar 7, 2010 at 11:52 PM
