2003 Ford Ranger
125,500 MILES • 4 CYL • 2WD • MANUAL
VONMAX
The truck wont take gas, it will take gas if i just barely push on the pedal seems to do great but when i try to speed up it wont do it, changed the fuel filter and seem to help a little
Jun 22, 2010 at 12:36 PM
  • 75,988 POSTS
If the clutch is not slipping,do below:
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 22, 2010 at 12:50 PM
