2003 Ford Ranger
APPLEPIE407
  • 2003 FORD RANGER
2003 Ford Ranger 6 cyl Four Wheel Drive Manual
y would a vehicles rpms go up to a regular idle then drop way down and almost die. The if u try to drive it just dies
Sunday, January 31st, 2010 AT 10:06 PM
  • 109,755 POSTS
Many things could cause this. Has the check engine light come on? Have you checked for vacuum leaks? Have you checked fuel pump pressure? And finally, have you checked the EGR valve for carbon build up?
Monday, February 1st, 2010 AT 8:11 PM
