2002 Ford Ranger transmission shift problem
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
BARTH
The overdrive on/off light is flashing. Transmission selector has to be put into 2-1 than to D to work. Works ok going straight to reverse. Works ok after it is put into D after going to 2 or 1. Fluid ok, change filter and 5 gts. of fluid no change. Transmission has always worked very well. No error on obd reader.
Oct 3, 2010 at 10:14 AM
BMRFIXIT
  • 19,053 POSTS
Flashing OD light while driving is an indication of tranny problems and tranny codes is set
Use a scanner tool and NOT an OBDII reader check for tranny codes
Oct 4, 2010 at 10:56 PM
