Where is the transmission range sensor located
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAM2084
where is the transmission range sensor located and how many prongs does the connector have for it? do you have a diagram of where it is located?
Mar 4, 2008 at 5:46 AM
MERLIN2021
  • 17,250 POSTS
Are you getting a code for it? Or can't start the truck? To install one of these you need an alignment tool....it's located where your shift lever is...
https://images.2carpros.com/forum/automotive_pictures/62217_Trans_Range_Sens2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Trans_Range_Sens1_1.jpg
May 4, 2021 at 2:51 AM
WILLIAM2084
yes we are getting a code for malfunction or out of position. Probable causes: Defective sensor or open or short circuited condition. Is there a way for me to adjust it or do I need to take it to a garage?
