Sometimes you can try to start the truck and it fires right up and you can try to start it a few seconds later and it will just crank over. I have replaced the plugs and wires and thought the wires were causing it so i put the second set on and it still does it. I have also put a fuel pump and both filters on it and still does it. Please help this problem is running my bank dry!
May 18, 2010 at 12:24 PM
