2002 Ford Ranger Starting
58,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRANDON224
Sometimes you can try to start the truck and it fires right up and you can try to start it a few seconds later and it will just crank over. I have replaced the plugs and wires and thought the wires were causing it so i put the second set on and it still does it. I have also put a fuel pump and both filters on it and still does it. Please help this problem is running my bank dry!
May 18, 2010 at 12:24 PM
  • 110,251 POSTS
Has the check engine light come on? When it doesn't start, have you checked to see if it is getting spark and fuel to the engine?
May 19, 2010 at 12:35 AM
BRANDON224
[quote:0627ee4eb3="Jacobandnickolas"]Has the check engine light come on? When it doesn't start, have you checked to see if it is getting spark and fuel to the engine?[/quote:0627ee4eb3]
No check engine light and i put a fuel pressure tester on it and it always has steady pressure. Im not for sure about the spark but if you keep cranking on it, it will eventually start. Never sure when it will do it though. Thanks for the reply i will check for spark.
May 19, 2010 at 1:39 AM
  • 110,251 POSTS
Check that and make sure it is a good hot blue snapping spark. If it is weak, it will make it hard to start.
May 19, 2010 at 3:49 AM
BRANDON224
[quote:1c83883839="Jacobandnickolas"]Check that and make sure it is a good hot blue snapping spark. If it is weak, it will make it hard to start.[/quote:1c83883839]
I checked the spark and its good. But yesterday i could not get it to do it. I started it about 20 times and it fired right up. It seems to do it when it is wet outside more but not always the case.
May 20, 2010 at 1:35 AM
  • 110,251 POSTS
Try this test. At night when it is dark, start the engine, open the hood, and mist water on the plug wires, distributor cap, coil... See if anything is arcing.
Let me know what you find.
May 20, 2010 at 4:12 AM
BRANDON224
[quote:5333ba011c="Jacobandnickolas"]Try this test. At night when it is dark, start the engine, open the hood, and mist water on the plug wires, distributor cap, coil... See if anything is arcing.
Joe[/quote:5333ba011c]
Ok it was raining last night so i checked it and it is arcing off the wire onto the a/c shield. This is the second brand new set of wires in a week that is doing this.
May 21, 2010 at 10:28 AM
  • 110,251 POSTS
Thats the problem. Since you had problems before, purchase wire loom and place it over the wires where they could arc.
Let me know if it helps, and thanks for using 2carpros.com.
May 21, 2010 at 2:46 PM
BRANDON224
[quote:bd0c51d665="Jacobandnickolas"]Thats the problem. Since you had problems before, purchase wire loom and place it over the wires where they could arc.
Joe[/quote:bd0c51d665]
That worked it starts every time! Thanks a million!
May 28, 2010 at 9:53 AM
  • 110,251 POSTS
Great! I'm glad it worked. You take care and let us know if you have questions in the future.
Thanks for using 2carpros.com.
May 28, 2010 at 4:50 PM
