2002 Ford Ranger starting
85,000 MILES • 6 CYL • 4WD • AUTOMATIC
WTRSKIADIC
I bought a 2002 ford ranger last january and had a pump replaced last march now when try to start it the will not run it just cranks until i cycle the the key 5-6 times then it will start and run for a second then die again
Nov 27, 2009 at 3:46 AM
MERLIN2021
  • 17,250 POSTS
http://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
Might have been a cheap pump...
Nov 27, 2009 at 4:18 AM
WTRSKIADIC
could it be any thing else
Nov 28, 2009 at 11:59 AM
MERLIN2021
  • 17,250 POSTS
The key part of your question was cycling the key 5-6 times, this will build fuel pressure, the fuel pump relay is energized for 2-3 seconds each time you do that, so it is building pressure. Did you test it? Also you could test for spark, but if it will run briefly, I think it's fuel related...
Nov 28, 2009 at 10:07 PM
