Starter Change
65,000 MILES • 6 CYL • 4WD • MANUAL
DENNYB
I removed almost everything but my biggest problem ist to get the starter out. I Disconnect the cables, and the lower bolt. The problem is that i dont know how to get to the upper bold and with which tool i tried everything. There is not enough place.....
Is there a trick or which tools do I have to use...
Thanks so much,
Denny
Dec 16, 2009 at 11:23 PM
OBXAUTOMEDIC
  • 3,720 POSTS
Hi Denny,
What you will need is a long extension (24" or 36"). You will need to come from the front of the engine it is a pain but seems to be the easiest way to get to the top bolt. Also a universal joint for sockets will come in handy. And may take 2 people.
This guide can help
Dec 17, 2009 at 1:52 AM
CLIPPERS8384
All of a sudden my truck has decided to go crazy. Once I turn the key it starts engaging and trying to turn over, when I get to the on position the engine starts but you can still hear it trying to engage. If I turn the key off it keeps engaging for about 10 minutes before it slows and finally dies off. I have tried to replace the ignition switch already and that didn't help. Please help!
Nov 11, 2019 at 10:07 AM (Merged)
FISHERMAN
  • 937 POSTS
[quote:f79614b6ae="clippers8384"]Other Category problem
2002 Ford Ranger 6 cyl Two Wheel Drive Automatic 68000 miles
All of a sudden my truck has decided to go crazy. Once I turn the key it starts engaging and trying to turn over, when I get to the on position the engine starts but you can still hear it trying to engage. If I turn the key off it keeps engaging for about 10 minutes before it slows and finally dies off. I have tried to replace the ignition switch already and that didn't help. Please help![/quote:f79614b6ae]
Hello !!
Remove the starter and bench test it, looks to me like the solenoid contact its damage or broken (the starter has power all the time by the positive wire from the battery) and the power "flows" inside to the starter motor.
99% sure of that`s the problem, check that and comeback with your findings.
Good Luck!
CLIPPERS8384
The solenoid was stuck. Took it to get tested and it unstuck. Thanks for the help! Truck is up and running and headed off for a 6 hour roadtrip.
FISHERMAN
  • 937 POSTS
[quote:ddd46461d1="clippers8384"]The solenoid was stuck. Took it to get tested and it unstuck. Thanks for the help! Truck is up and running and headed off for a 6 hour roadtrip.[/quote:ddd46461d1]
Hello !!
I`m glad to hear that!!
thanks for choose 2carPros!
Good Luck !!
DAVID0409
How do i remove my starter on my ranger. i cant seem to find the bolt locations
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_starter_1.gif
CHAS S
I am told my slowly leaking oil pan is imundating my starter with oil and it will only be a matter of time brfore starter stops working. Since that was told me, starter seems to be getting gradually less and less effective...To fix my oil pan situation would be $ 800 some odd...Wouldnt it be cheaper to replace starter? And can I do that myself?
Nov 11, 2019 at 10:08 AM (Merged)
  • 110,251 POSTS
A starter would be around 150.00 and you could replace it yourself. However, that won't stop the oil leak and it will happen again over time.
