2002 Ford Ranger running horribly!
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
LINZBGOOFY
While driving down the interstate, my truck suddenly refused to go over 60mph. It idles VERY low, and in doing so, makes the entire truck shudder. Diagnostics showed a code that said my ignition coil was bad; so I replaced it, along with spark plugs and wires. The ignition coil code still shows up on the computer, and the problem still exists.
Dec 7, 2009 at 7:00 AM
BIGJIM79
  • 239 POSTS
what color is your oil?
Dec 7, 2009 at 5:38 PM
LINZBGOOFY
its normal colored, just had it changed about a month ago
Dec 8, 2009 at 3:20 AM
BIGJIM79
  • 239 POSTS
[quote:d81e7ac66f="linzbgoofy"]its normal colored, just had it changed about a month ago[/quote:d81e7ac66f]
I would look at the compression and the engine ground that goes from the engine to the body. I would like to know what engine and firing system you have as there seems to be a conflict if it shuts down.
Dec 8, 2009 at 12:58 PM
LINZBGOOFY
I found a good family connection through a dealership...they think its the engine control module...its around a $400 fix so I'm REALLY hoping thats not it.
Dec 9, 2009 at 3:22 PM
