2002 Ford Ranger removing the front rotors
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
CATCHER22
I have done several brake jobs on small cars. I have never done rotors on a truck before since this is my first truck. I am wondering if I need to remove the wheel bearings in order to replace the rotor on my light truck and if not how do I get the old rotor off
Jan 14, 2010 at 11:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
For 2WD, yes the hub grease cap, cotter pin, nut retainer, spindle nut, and front wheel outer bearing retainer washer & outer front wheel bearing must be removed prior to removeing brake disc
Jan 14, 2010 at 3:14 PM
