2002 Ford Ranger Poor starting
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRUCKER100
The truck runs well, but after a stop of one hour or more takes much cranking to start, Main dealer says new fuel pump $1000 plus,but that seems wrong, because if it is without fuel the pump should run, no sign of leaks in system, where is fuel filter? I am told pump is in top of tank, as it is easy to lift the bed off, is this the way to go?
Oct 24, 2008 at 8:30 AM
BMRFIXIT
  • 19,053 POSTS
I would do a simple fuel pressure test before replacing (maybe a good) fuel pump
and dropping the fuel tank
Fuel filter on the frame rail
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 24, 2008 at 3:27 PM
98RANGERXLT
  • 301 POSTS
fuel pump is on the frame rail under drivers door.
Oct 27, 2008 at 5:46 PM
