2002 Ford Ranger Poor starting
TRUCKER100
  • 2002 FORD RANGER
  • 6 CYL
  • 118,000 MILES
The truck runs well, but after a stop of one hour or more takes much cranking to start, Main dealer says new fuel pump $1000 plus, but that seems wrong, because if it is without fuel the pump should run, no sign of leaks in system, where is fuel filter? I am told pump is in top of tank, as it is easy to lift the bed off, is this the way to go?
Friday, October 24th, 2008 AT 3:30 PM
BMRFIXIT
  • 19,053 POSTS
I would do a simple fuel pressure test before replacing (maybe a good) fuel pump
and dropping the fuel tank
Fuel filter on the frame rail
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Friday, October 24th, 2008 AT 10:27 PM
98RANGERXLT
  • 301 POSTS
Fuel pump is on the frame rail under drivers door.
Tuesday, October 28th, 2008 AT 12:46 AM
