Oil Pressure Switch (2.3L)On left rear of cylinder head.
Oil Pressure Switch (3.0L)On right rear of engine.
Oil Pressure Switch (4.0L)On lower left front of engine.
OIL PRESSURE SWITCH
Removal & Installation
Disconnect the battery ground cable.Disconnect the engine control sensor wiring from the oil pressure sensor.
Fig. 150: Disconnecting Oil Pressure Sensor
Courtesy of FORD MOTOR CO.
Remove the oil pressure sensor.
Fig. 151: Removing Oil Pressure Sensor
To install, reverse the removal procedure.
Sunday, April 5th, 2009 AT 8:05 AM
