Engine surges when driving in any gear at less than 2000 rpm. No surge after reaching 2000 rpm. Dealer diagnostics do not indicate electrical problem or any codes. New Motorcraft plugs and wiring harness did not correct.
If the maps sensor is not performing, will it generate a "code" to indicate a problem.
May 1, 2009 at 10:53 PM
