2002 Ford Ranger oil pan leak
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
NUTHOUSE
How much should new oil pan cost with instalation?Is it true that the engine has to be lifted out? Can anything else be done,it,only a small leak? I know that in time small leaks become large leaks. Thanks for your help.
Jun 11, 2009 at 4:25 AM
BMRFIXIT
  • 19,053 POSTS
I would say about $600 to $700
engine need to be lifted and or tranny out
you can temporary repair it by using epoxy
will not last for long only as a temp .
good luck
Jun 11, 2009 at 10:56 AM
