2002 Ford Ranger no turn signals/brake lights/battery drain
2002 FORD RANGER
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANNY81119
Dear sirs,
how can I trouble shoot this problem(s).
I noticed that the air condition compressor did not shut off and began to freeze up the condensor. Then my battery began to drain. I pulled the battery cable off, the next morning the turn signals/emergency flashers/and the brake lights have stopped working. I replaced the flasher but that did'nt help.
Oct 31, 2008 at 12:23 PM
BMRFIXIT
  • 19,053 POSTS
By disconnecting the battery u triggered the alarm system
and you have to disable it
if u don’t have the clicker to do so
try locking and unlocking the door using the key
if that did not work
disconnect the battery , place key in the ignition and turn it to ON
reconnect the battery
and start that should take care of it
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 2, 2008 at 11:00 AM
