2002 Ford Ranger Idling Promblems
96,600 MILES • 6 CYL • 4WD • MANUAL
NKFF564564
I have a 2002 Ford Ranger Edge with the 4.0 L SOHC and I have been having Idling Problems with it.
Whenever I push the clutch into stop it will Idle at a different RPM everytime. I replaced the Idle Air Control Vale and it did not fix the promblem. My check engine light is on and I have attempted everything I can think of. Any suggestions.
Jul 17, 2008 at 2:37 PM
KHLOW2008
  • 41,812 POSTS
Hi nkff564564,
If the CEL is on, you should scan and find out what is causing it.
Looking for a needle in a haystack is one thing, looking for the correct haystack would make things more complicated.
Jul 17, 2008 at 10:07 PM
