2002 Ford Ranger Horrible rattle.
81,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRITTMIESTER3
I have a 02 Ranger 4x4 have a really bad noise (like a rattle or vibration) coming from the front passenger side under the hood. I lifted the hood and cannot pin point the location of the noise I have changed the Belt tensior pulley and alt. (anything in the general area of that noise... still there is get worse when it is in park in Idle... Then when in gear still does it but not as loud at least doesnt seem as loud.
Nov 27, 2009 at 7:10 AM
MATHIASO
  • 1,209 POSTS
Have you checked the oil level?
Nov 27, 2009 at 8:27 AM
BRITTMIESTER3
Oil level is normal... new oil acually , Trans level is normal also.
Nov 27, 2009 at 8:59 AM
MATHIASO
  • 1,209 POSTS
The oil pressure should be checked to make sure that the noises are not valve train related.
10 PSI of oil pressure for every 1,000 RPM of engine speed.
what is the weather where you're leaving and what kind of oil your using?
Nov 27, 2009 at 1:35 PM
BRITTMIESTER3
I live in East Texas so right about now it changes between 50's- to 60's and I use castoral gtx 5w-30
Nov 28, 2009 at 1:23 AM
MATHIASO
  • 1,209 POSTS
5W-30 is good for year around,
Have the oil pressure check and repport how much it is.
Nov 28, 2009 at 9:17 AM
