2002 Ford Ranger Heater Fan
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
RON BAVOL
Fan does not work. Or maybe only is stuck on low. Hard to tell. (I feel a little are movement)
Heat/AC/Direction controls work great.
Dec 17, 2009 at 3:15 AM
JDL
  • 16,098 POSTS
Welcome to the forum, Did you check for voltage at the blower motor connector? You should be able to get at the blower motor, under the hood, firewall. You can take connector loose, turn the key on and hvac controls, use a testlite, check for voltage, Pink wire with white tracer. The various speeds, on/off are controled on the ground circuit. Ground is orange wire with black tracer. I just needed to add, voltage to the blower motor, does go through a relay.
Dec 17, 2009 at 3:57 AM
