2002 Ford Ranger hard to start
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
TERMITER007
when I first start the engine it takes a while to fire off each and every time I start it. Will run fine after it starts. Is there a cold start valve or somrthing on this truck?
Jan 10, 2010 at 7:15 AM
  • 110,248 POSTS
It sounds like you are loosing the fuel pressure prime. Here is a how to for checking pressure. PAy special attention to the fuel pressure drop off when you shut the key. It should hold pressure. If it drops, there is a leak somewhere.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Jan 12, 2010 at 12:28 AM
