I need to replace bearings and seals on the front left side drive axle coming out of differential. How does one go about doing such?
Jan 7, 2009 at 7:03 AM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
Here is the information you requested. You must first remove the CV axle to gain access to the differential bearings and seals. Here is a tutorial showing how to remove and replace CV axles:
I've attached picture steps below on how to replace the front differential axle bearings and seals on your truck. Hope this helps and thanks for using 2CarPros.
