2002 Ford Ranger DRIVERS SIDE DOOR PANEL
MR--JIM
Interior problem
2002 Ford Ranger 6 cyl Four Wheel Drive Automatic 70K miles
HOW DO I REMOVE THE DRIVERS SIDE INTERIOR DOOR PANEL TO GAIN ACCESS TO POWER WINDOW MOTOR? CLIPS, SCREWS? RANGER HAS POWER LOCKS, WINDOWS,& MIRRORS
THANKS
Jan 25, 2010 at 12:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the front door trim finish panel screws.
Separate the front door trim finish panel from the front door trim panel.
Disconnect the power mirror and power door lock electrical connectors, if equipped.
Remove the power window switch screws, if equipped.
Remove the front door trim finish panel.
Remove the front door trim panel screws.
Remove the front door trim panel.
Position the water shield aside.
Jan 25, 2010 at 12:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the front door trim finish panel screws. Separate the front door trim finish panel from the front door trim panel. Disconnect the power mirror and power door lock electrical connectors, if equipped. Remove the power window switch screws, if equipped. Remove the front door trim finish panel. Remove the front door trim panel screws. Remove the front door trim panel. Position the water shield aside.
https://images.2carpros.com/forum/automotive_pictures/261618_1_100.jpg
Jan 25, 2010 at 12:30 PM
