2002 Ford Ranger DPFE sensor
2002 FORD RANGER
64,000 MILES • 6 CYL • 4WD • AUTOMATIC
PEGGYSTAZZIE
Where is the DPFE sensor located and what is the code for the check engine light after the sensor is replaced to turn the checkengine light off? Also where do you enter the code?
Jul 16, 2009 at 10:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
left side of engine, pictured below..
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_80.jpg
you need a diagnostic scan tool to delete the stored trouble codes, or just disconnect negative battery cable for 10 minutes then reconnect..
Jul 16, 2009 at 3:32 PM
