2002 Ford Ranger cold running condition
75,000 MILES • 4 CYL • 2WD • MANUAL
PRITLE
engine seems to cut out alot at lower rpms down shifting helps it acts like an open choke problem after 15 minutes or so it seems ok any ideas
Mar 27, 2010 at 8:27 PM
  • 75,988 POSTS
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 27, 2010 at 10:30 PM
