code p1537?
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAEFENOC
i have a p1537 code. intake manifold runner control stuck open (bank) 1. i can not find any info on this problem and where exacty where it is on my truck. can u help with any info or diagrams where this is located.
thanks
steve eland
Jan 15, 2008 at 2:31 AM
MERLIN2021
  • 17,250 POSTS
I can't find a picture, but look for an actuator on the intake, that has both electrical and vacuum connectors on it, disconnect it and remove it, the carfully try to move the lever by hand. be carful, the return springs are strong! Problem is either the plates are stuck open, or maybe a bad actuator, disconnect the neg batt cable to do this...
Jan 15, 2008 at 3:03 AM
