2002 Ford Ranger 3.0L
TODDNEL
I replaced the fuse and wiper motor (which was seized) on my 2002 Ranger. Alas the wipers still do not work. Is there a wiper relay on this model and if so where the heck is it? The switch is good.
Thanks
Oct 3, 2007 at 3:08 AM
FAIRRACING31
  • 150 POSTS
Todd, your wiper relay is built in the wiper motor. Turn your key on, turn your wipers on. Check with a test light or ohm meter to see if you are getting voltage to your wiper motor. If you are not, and your sure your fuse is good, it's most likley the switch on your steering column.
Oct 7, 2007 at 10:28 AM
