2002 Ford Ranger 2002 Ranger Tune up question
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAUCHRJ
My Ford 2002 Ranger was running rough so I replaced the spark plugs. Now it is mis-firing badly. Should I have also changed the spart plug wires at the same time or is there simething else I should have done. The old set of spark plugs had at least 60K miles on them.
Dec 24, 2007 at 4:36 AM
FAIRRACING31
  • 150 POSTS
I would double check your plug wires. It is possible you crossed some of your wire's. At 60,000 it's not a bad ideal to replace them.
Dec 28, 2007 at 9:01 AM
